ab valve?!
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
that-son
Car: '81 datsun 720 4x4 kingcab
hey guys. can't find an ab valve anywhere but i found a diverter valve. are these two one and the same? thanks!
ezb57e
AB valves don't divert anything, and they are not related to the Air Injection system.
I don't think anyone would confuse them.
that-son
one ab/diverter valve on the way.
apparently rockauto, haynes and the nissan dealership in my town are confused like me.
thanks for your help.
ezb57e
Diverter valves are part of air injection systems, and divert the output of the air injection pump to the atmosphere.
Anti Backfire valves merely let air into the exhaust to counteract the large amount of fuel that can be present on deceleration.
that-son
my diverter valve arrived last thursday and i have now plugged all the leaks. including one diaphragm (that drove me nuts) from the charcoal canister. the rubber had a hairline crack which i repaired with a thin smear of rtv. prior to that i squeezed some rtv on oiled wax paper, let it cure overnight and then i soaked it overnight in a jar with half acetone and half gasoline. nothing happened to it after 24 hours. it did not turn to mush... nor did it disintegrate so i used it to repair the diaphragm and it seems to be holding up. anyway this post is about the diverter valve i ordered from rockauto.
for those looking for an ab valve... rockauto lists it as a diverter valve. the nissan part no. is 14835 u6701.
and here are the aftermarket part nos.
CARQUEST 73-3433
AIRTEX 7D1063
WELLS DV36
BOSCH 1 987 947 604
STRD. MTR. DV23
BOSCH 910416-1163
i was told by the parts dealership in my town that the valve is also known as:
1. anti backfire valve
2. ab valve
3. air bypass valve
4. diverter valve
the item i ordered said "fuel pump" on the label but had nissan and the nissan part no. stamped on it. go figure.
Return to “Datsun 720”
