After its all clean, putting it back on is relatively easy. Make sure you didn;t lose the gasket, mine was still stuck to the manifold. line the unit up and place all 4 bolts in before you tighten them. I recommend plugging the brown wire back in first, once the unit is screwed in it is very difficult to reach/see the plug.
after both wires are plugged in, hook up both hoses you removed, and your done.
It took me about 4 hours total...that included taking out, cleaning, drinkin a soda and sittign for a few minutes, and putting it back in. The only other car things I've ever done so far was help /w water pump install and replacement of my headlight motor. So you can estimate how long this will take you off of that. I also have real big hands which didn't help
After cleaning and reinstalling I took it for a test drive once the car was up to temp. It ran PERFECTLY. The idle didn't even THINK of dropping down low, it would come to a nice stop around 800 RPM every time, tested it at about 4 stop signs and pressed the clutch in while going 70-80 about 7 times, all with perfect results...then I drove to my friend's house a few hours later and the problem was back...not quite as severe though. Sure hope this helps you out Smurf
