The pressure assumming you are not at a tuned point [where the reflected wave reinforces the incoming atmospheric pressures] is 14.7 LESS the restriction or 14.2 psi at the absolute instantaneous peak, but the restriction starts out high as the valve just opens reaches a peak then declines......so the total or average air flow......guassian/Normal curve.The ring sealing is not really good enough to suck in air, air just flows in to reflect the void as the piston drops! This is the vacuum you read across the intake restriction.
The vacuum is [shows inversely] a direct relationship with the volumetric efficiency.
When heads are measured on a flow bench the industry standard is 28" WC [how many CFM at 28" WC] which is equal to roughly 1.0 " HG. .....or 1/2 a psi.Years of trial and error have develop this optimum point
If you think about the distribution of the various restrictions: 7.5 outside air to MAF, 5.0 in MAF itself, 2.5 in hose to throttle body we are at 15.0 to input of throttle body total at 6500 rpm! Leaving 13" or so for the TB, plenum, runner, heads and valves.
The main problem is at low rpms the cam opens the valves for 248 degrees [seat to seat] which means that for 248-180= 68~~48 degrees {VVT} [really about half this as the valves needs time to move off seat] air is being forced back out as the piston rises until the rpm increase enough to get the air speed up enough so that this reversion becomes a packing [supercharger effect [trying to walk against the wind] at 3,000 rpm or so!
Life in a street engine is always a compromise against idle low speed operation vs high rpm peak power and the Q [2] 1.5 inch diameter intake valves are on the big side [1.76x2=3.53 square inches -----much bigger than a single 2.02" [3.17 square inches]racing valve for a 350 Chevy which makes 400-450 HP].
http://www.edelbrock.com/autom....htmlh ... rules.html
The Q engine is optimized for PEAK TORQUE [maximum numeric value] the area under the 3,000-4,500 rpm band is optimized.
A maximum HP optimization would be at 7,300 rpm which means the peak torque [same amount would produced at 5,500 rpm] would yield around 460 HP give or take a few.......but the engine would need to idle at 600+1500[amount torque rpm was raised]= 2100 rpm..............you could lower this [to 1200] by raising the compression by 4-5 points[say 15:1] and burning Methanol........notice that the Indy 4.5 Infiniti motor only made 375 lb/ft at best just 38 or 11% more than a Q with JWT ecu.
Physics does interfear with wishes!
