aac/iacv cleaning
24DSXY1
Car: 1991 NISSAN 240SX
My idle is high(1500rpm on start and 1000rpm warmed up) and I was told to clean my aac or iacv. Can I just use sea foam to clean them on the motor or do I have to remove them from the motor?
TDS
Car: 2008 G35
good question. I also would like to know. I seafoam my engine once in while but I always thought youd clean the aac like the maf.
JDS Performance
24DSXY1 wrote:My idle is high(1500rpm on start and 1000rpm warmed up) and I was told to clean my aac or iacv. Can I just use sea foam to clean them on the motor or do I have to remove them from the motor?
Remove them, I never used any seafoam before, I thinks its more of a cutting corners type of deal, which I never do on my priceless cars!
neverlift
really I like seafoam b/c it WORKS. So you would rather remove your intake maifold,or whatever part attatched to it, and then buy gaskets for the pieces you took off, instead of using some seafoam in a vac line. It works good, My 180xxx mile intake manifold were ubber clean. Although the iacv was a bit dirty ,it worked till I removed it.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
You can remove the hose going to your idle control unit off the air intake tube..And spray alot of throttle body cleaner up in there..With the car on or off..That works and is easy to do..But might not fix your high idle..Have you tryed adjusting it yet?? On the throttle body or the idle control screw?
JDS Performance
neverlift wrote:really I like seafoam b/c it WORKS. So you would rather remove your intake maifold,or whatever part attatched to it, and then buy gaskets for the pieces you took off, instead of using some seafoam in a vac line. It works good, My 180xxx mile intake manifold were ubber clean. Although the iacv was a bit dirty ,it worked till I removed it.
Well if it works this good, I would try it yes!
I just figure it was something that would end up biting you in the *** later down the road...
24DSXY1
9240sx wrote:Have you tryed adjusting it yet?? On the throttle body or the idle control screw?
I haven't tried adjusting the idle screw yet. It's hard to see the idle screw with the abs crap in the way, do you have a picture it?
