Valvebounce »
https://forums.nicoclub.com/valvebounce-u144391.html
Wed Mar 17, 2010 9:31 pm
hey man, if you're fitting the H879 head to an early A12 (Front dizzy, as oppposed to mid dizzy) then you WILL ned to modify the oiling for the rocker gear. Just take a good look at at where the oil exits the block deck, and compare the H89 head to your old one. (If you have a front dizzy block that is) You'll need to just drill a wee hole to allow oil to reach the rocker gear.
Which NZ forum were you on?
