book-ends »
https://forums.nicoclub.com/book-ends-u3879.html
Wed Sep 10, 2003 8:55 am
Hello,
I just wanted to give everyone a heads up in case they wanted to purchase a Whiteline front stabilizer bar:
If you set it to the stiffest setting, the bar hangs pretty damn low to the ground. How low? Well, I turned off the road to pull into a gas station and had to diagonally cross a gutter. I hit it going about 20 MPH and heard this ka-pow! followed by the car bucking briefly. I pulled up to the pump, hopped out, got on my knees in front of the car and started yelling like a crazy man........
When the suspension compressed, the stabilizer bar caught the lip of the gutter and folded backward......maxing out the allowed travel, completely deforming the upper brackets and putting a 15mm diameter dent across the front of the oilpan!!! Luckily the oil pick-up wasn't bent so the engine is still being lubricated.........but damn!
I'll have to hit the junkyard this weekend for new brackets. The poly bushings were fine but I had to cut through the brackets with a Dremel tool to get the stabilizer bar off........
240's ride pretty low to begin with, but at least now I've learned my lesson......
