A "will this fit" question
wchs85
Car: 1995 NISSAN 240SX SE KA24DE
I need to know if the following wheels will fit on my 1995 240sx (S14) that has no suspension or brake modifications. Any help is appreciated.
Front----- 17x9 +15Rear------ 17x10 +35
Keep in mind that these are FN01R-C's. Also put into consideration different tire sizes. Thanks
Juujai
come on now. fn01rc is like one of the most common wheels put onto the 240sx... there is no way i would ever put fn01rc with 5 lug lol. it makes all the s13 guys feel so sad converting to 5 lug. watching lucky s14 se guys slap fn01rc
you look like you're still stock height so probably no need for fender roll. so slap them on with a proper tire size i prefer 40 series some like 45 series. and adjust negative camber until it lines up with the fender.
look into a camber correction kit/rear upper control arms. you can run a slight stretch or proper sizing depending on your style of fit. 235/40-255/40
