xagna wrote:I got my differential gears welded with help of a friend and am about to put it back together with rest of the diff.
When I tried to put the differential gear back into the diff case, I realized that I only have 1/3 inch thick ring, 1/6 inch thick ring and a shim. Do I have everything necessary for the assembly or am I missing something? I am thinking I might be missing another outer race. Or could the 1/6 inch thick ring be the other outer race?
What do you think?
when i welded my friends diff last weekend, when we took it off it had a big ring and small ring on the left, and a small ring on the right. your deff. missing the other ring. you were supposed to have 3 total, 1 big and 2 small. then you also have 2 bearing races, and 2 bearings.
