Nicksemianiw wrote:I just find it a bit confusing, sory for being a pain i wasent sure, and like i said before i dont want to make a 1000 $ mistake.
Nick
Simply put, you can't make a mistake (theoretically). No matter what lsd you upgrade to, it will perform better than your open diff. Case closed.
And please, next time you post, read the differential pages & carefully read what companies sell (kaaz replacement for vehicles EQUIPPED w/ open -> like the other guys said, read).
Don't feel obliged to post back right away. Read what everyone's said, read the links, do some searching... THEN post back.
Most people on here are nice, but like Camel said, if you keep asking the same question w/o showing signs of at least taking some time and doing some research, then people are going to stop helping you.
Open: what you have -> the worst, but "can" be used, some argue you can't "truly" drift in an open diff, but it's all technical over zealous crap. If you can slide around in an open diff & control it, then when you go to lsd, you will be even in more control.
VLSD: cheaper choice - goes around 200-500 depending on condition and what you get. You should SEARCH for these threads, there are plenty of threads on which ones bolt up, etc.
1.5 way LSD: good for an overall improvement in everything. Best compromise so to speak for a daily driven car w/ drifting & dragging.
2 way: good (arguably the best for drag/drift) but less drivability. You can search for 2 way lsd on these boards (as well as google) and read the issues people have w/ 2 way lsds and their clunking/noise / drivability, etc.
And just so you know, if you post one more time asking which lsd to get now that we've all spoon fed you the information, there's gonna be some gangsta **** going up in here (hahahaha, just saw "Be Cool" - couldn't help it).
