mel1mls wrote:av8or you stated you would be posting pictures. Would love to see them. Also, what are the steps to safely removing the console. I dont want to force anything and break anything. Thanks for the help, all.
sorry buddy... been busy with work lately... didn't think anybody would be interested... anyway here are some pics as requested...
1. pull this "thing" down...
2. remove this lock after which you can safely remove the gear shifter handle by pulling it up..
3. and remember to put your gear to neutral so you can remove the console..
4. gently remove the console by pulling up from the rear..
5. put the console to the side as shown... don't worry, there is enough slack from the wires to do this..
6. look for these wires located on the right side of the shifter.. a green and a gray one.. disregard the brown wire
7. cut both wires and switch connections (both green to gray)...then "tape" them up...here is what they look like after "the operation"
your are done.. put back the console and enjoy.. now PUSH IS DOWN AND PULL IS UP...
Modified by av8or at 8:34 PM 10/12/2008
Modified by av8or at 8:35 PM 10/12/2008
