A/t problems still
subzero9935
Car: cars
Continued from maxima technical was told to go to online mech: ok so i took it back to the transmission place and they dropped the pan and looked at it and supposedly replaced the solenoids again but? The rpms still bounce around when lowing down fast or just slowing down to stop. It bounces off the lowest rev, (when car starts shaking), and then goes back to normal, and sometimes it just sits at 500 rpm and the car vibrates (but when i shift to nuetral when stopped it goes to normal). They said that the torque conv was fine ( no shavings in pan) and it stopped whining a while ago and hasn't did it since. But today when taking off fast to cross busy intersection my car starts out in like 3 gear (which does it quite freq) and i had it floored and it would not shift to lower gear. I had to let off and stomp again then finally worked. Is there maybe a trans comp problem? Or should i just replace the tps sensor? This is really driving me CRAZY!! PLEASE HELP!!!!!!!!!!!
Thanks
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
Did they properly adjust the kickdown bands?
subzero9935
Car: cars
i didn't know that was possible but will it help my coming to a stop and idling problem
