audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Wed Mar 10, 2004 3:22 am
nistech has been swamped recently....
I'm not going to try and diagnose the problem (much) as I am not a transmission person nor do I have the documentation available like nistech does. If nistech has a chance to answer your question, that would be preferred.
While I find it great that you are attempting to figure out the problem and resolve it yourself, I also have to question it. You paid good money for a supposedly "well reputable trans shop" to fix the problem for you, yet you are still having the same issues. Why are they sending you home with a vehicle that is not functioning properly and why did they replace the solenoids again if they had fixed it in the first place? Something is very fishy with them. For $1500, I would have been camped at their door to make sure they fixed the actual problem with the vehicle. Sounds like they charged you $1500 for nothing.
Now, if you still question the TPS, have you looked at replacing it? Since I have heard numerous stories of shops disconnecting the SES, have you checked the ECU to make sure there are no diagnostics codes listed?
Cycling the key 3 times as nistech suggested will reset the ECU (I believe). Have you tried this and did this give any temporary changes to the problems you are having?
