A/T Oil Temp, Brake, ABS Lights ON. Battery 18v!
rgk
Car: 02 Pathfinder LE 3.5 auto 4x4
Hi all,
No fault codes stored or pending, but the above lights are on.
After 6+ years, my battery finally bit the dust. When I jumped it, the A/T Oil Temp, Brake, and ABS lights were off and the alternator was charging the battery just fine, 14v.
I trickle charged the battery, but it wouldn't charge over 3v, so I replaced it with a new one.
I put the new battery in, and the lights are back. I just checked the voltage and it read 18v while the car was running!
Is this a bad voltage regulator, and should I replace the alternator, or should I be looking at something else?
Thanks!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's no external regulation on an '02, the alternator's regulation is internal. So 18V can only come from a bad alternator. Don't run it for long that way, stuff on the CANbus will definitely start blowing up.
rgk
Great, I'll get an alt ordered ASAP.
I have not run it long like that. It definitely doesn't sound right.
Thanks.
Mike W.
Car: 2003 Infiniti QX4 with a drinking problem. Gone but not forgotten
2002 BMW 525it
2002 BMW 530i/ manual trans
The dark side, 2008 4Runner.. We'll see.
Just to make sure, check your voltmeter. I've seen some digitals that would read high when their battery was bad, 16 or so, engine off, so a reading of 18 is believable when running. Just a quick check of another vehicle, you don't need instrument grade precision.
VStar650CL
Technical Expert
Mike W. wrote:
Sat Jun 26, 2021 9:26 am
+1, good thinking.
rgk
Multimeter is good, regulator is bad. Thanks guys.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
rgk wrote:
Sat Jun 26, 2021 12:34 pm
do you mean the alternator is bad?
VStar650CL
Technical Expert
04pathse wrote:
Sat Jun 26, 2021 4:32 pm
Same thing, they're unitized. Yes, the regulator inside his alternator is bad.
