munjal »
https://forums.nicoclub.com/munjal-u85207.html
Sun Oct 25, 2009 1:11 pm
An odd issue came up with my '98 max last night ....
When cruising at low speeds around 40 mph and 1500 rpm....the car was ...sort of bucking....as if going in and out of gear.
However the issue immediately goes away when I give a little more gas and raise the rpm to over 2k rpm or higher...or turn off OverDrive and go into third gear....
Issue seem to come up after about 5-10 minutes of driving after everytime I stopped and parked the car somewhere.
I checked my fluid level this morning (transmission) and it seems fine, however I did see really small/fine bubbles on the dipstick...the kind I heard of when you have too much fluid in the transmission...don't know if this is the case or not.
I did replace the fluid about 5-7k miles ago, and earlier this year, on two separate incidents, I got a CEL code for Torque Converter Clutch solenoid, however in both cases the code went away on their own after a few days. I don't know if this is related
At the moment, I have no codes, (or lights really) but I have to borrow and reader and try to pull the codes anyways, if any exist in the system.
My Car specs: Stock to the bone 1998 SE, with 210K miles.
Only else comes to mind, is could this be a possible fuel issue instead of the transmission, since it only occurs at low RPMs after a few minutes of driving?
Also, I have not driven the car today to see if this issue has returned.
Any and all of your wise feedback is greatly appreciated.
