t.mcginley.jr wrote:Your speed sensor is probably bad or the connector has some corrosion in it. I would try taking the connector off, cleaning it, putting some dielectric grease in and reseating it and see what happens. If that doesn't fix it, you might need a new speed sensor. The ECU uses the speed sensor to reduce the power steering when you are at higher speeds to firm up the steering feel. So the ecu probably thinks you're going way faster than you are and locks up the steering.
I finally got around to doing the labor, it was actually damaged bad so I replaced it with a new one. It works perfectly fine now. Thanks for that one!
