Tru180Kid wrote:how hard is it too take the Pilot bearing out of the automatic transmission
there is no pilot bearing in the auto trans. Pilot bearings are used for manual transmission flywheels.
Auto don't use a flywheel persey. A torque converter bolts to the flywheel like thing and the trans input shaft goes into that.
Depending on the car (i did the auto to 5speed for a ca18de pulsar) You will need to grab a clutch pedal assembly plus switch (if your car doesn't have it). Make sure you get another mini engine harness and there is a plug that will go to the trans (it did on mine, prolly different on a RWD setup)
Anyway, its pretty easy, just make sure you have a parts car or something or at the very least get all the parts listed above.
Only benefit of having an auto motor is that it is less likely that it was beat on.
