I just put a 96' engine in my 89'. I am connecting the 96' harness to the s13 wiring in the dash. There is a dash harness plug on the 89' right behind the glove box which should be white or on some years brown that was used with the 89' harness. It has about 13 wires coming from it. I found some info on color matching it to the new harness.
My question on that is where do I splice into on the 96' harness from the 89' dash plug?
1. Do I splice into the main plug that connects on the ecu itself.
or
2. The other plug also on the 96 harness in the dash area (a white one near he ecu plug) which has about 25 wires and looks like a minature ecu plug and has another little white plug with about four wires coming from it. This one doesn't plug into anything so I thought it would be okay to splice into since it's just a plug hanging that doesn't connect into anything.
Also about the plugs next to the battery ( e10 and e9)! Do I run line from the plug under the dash to those. I was looking at the drawing diagram on heavy throttle.
http://heavythrottle.com/ Its under Install FAQ then click on electrical wiring then scroll down to the drawing. I am using a 96' harness and dont have the f10 or f8 plugs. I thought the best thing to do is run the lines from under the dash through the firewall to the s13 plugs near the battery. Is this right?
I know this forum is filled with people who know, and hopefully I will also know soon.
Thanks for any help or info on this!
