RobertN »
https://forums.nicoclub.com/robertn-u101441.html
Thu Jul 24, 2008 5:17 am
For the last three months of owning my EX I have always wondered why that "tab" on the end of the sun visor does not pull out for those situations where the sun visor is not "long" enough to cover the direction of the sun through the side window. Prior to my EX I owned a G37 and on that sun visor it had a pull out from the end of it for that reason. So when I saw the plastic tab on the end of the EX visor I just assumed it should pull out also. So...........I tried and obviously it does not pull out. I just accepted that the visor does not have that option and it was a poor design.
Along comes yesterday....................................As I sit in my car talking with someone on the blue tooth I just happen to swing the visor over to the side and AGAIN wished that stupid plastic tab pulled out. So I pulled on it again and the entire visor slid out along the rod it is installed on!!! WOW.....the visor was designed to cover the sun along the entire width of the side windows!!
OK.......so it took me 3 months to discover this! But how many of you did not know it until you read this???
And yes even those of you that knew it all along can comment on my "slow learning process"!!
