a Stupid noob question UGH
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
OK So i did a 5 spd swap on the new 240sx now the TPS is set at 35 degrees and my coolant temp sensor is bad. I will replace it but where should this TPS be at cause it runs like weak sauce. i think 44 degrees but not 100% on that
vancouverbc
Car: 1991 240sx
sean8564 wrote:OK So i did a 5 spd swap on the new 240sx now the TPS is set at 35 degrees and my coolant temp sensor is bad. I will replace it but where should this TPS be at cause it runs like weak sauce. i think 44 degrees but not 100% on that
tps is set by reading the voltage. best to use consult cables. you read voltage manually by sticking probe in connector. connector obviously has to be connected. should be around .45 v
