A Strange One!
Pasillas
Need a temperature sending unit. It does not have a data plate on it but the engine had some markings 1982cc Nissan 03302 50K or F250K. I believe it was made in 2005 or somewhere around there.
This is actually on a King Forklift that was built oversees a while back and is no longer in business. The engine is a Nissan and we are hoping that we can find out if engine was used on another application. That way we will be able to find parts for it.
Heavy
Car: 1992 Mr.Two, 1996 LS4HUNNID, 1999 Appliance on wheels.
im guessing Nissan H20 or a variant of it, still searching for parts.
Pasillas
Any help would be greatly appreciated!!!!
300ZXttZMAN
Yea slightly strange to say the least...
Welcome to Nico!
Pasillas
Any Updates? Still searching on my side and I can't find anything.....
NolimitZ32
Have you tried contacting equipment rental companies or heavy equipment suppliers?
Pasillas
We are a Forklift dealer and our Parts Department can't find it. I am a sales person in charge of the account so I am trying to assist the customer. He knew when he bought it why he got such a great deal on the lift.
NolimitZ32
I see, well in that case I think you are SOL. I work with heavy equipment so if I see one randomly I'll try to get you some info but otherwise sorry can't help ya.
Pasillas
Thanks....at least I tried!
Heavy
well you could always try a temperature sending unit from any 4 cylinder nissan around that year, its worth a shot
300ZXttZMAN
Try rock and dirt.com then you may be able to find someone parting one out..
Good luck!
Dattebayo
A guy I talked to at the McLean Day fair today happened to be near the booth and works for a Forklift repair shop in the area. He mentioned that Nissan used the same temp sender for all it's engines from 95 to 2010? I dunno if it's true, but there you have it.
:gotme Hope it helps.
audtatious
H20
The H20 is the most-common member of the family. Displacing 2.0 L (1,982 cc) thanks to a larger (87.2 mm) bore, H20 engines produced around 99 hp (74 kW) and 123 lb·ft (167 Nm).
Applications:
1966-1968 Nissan Junior 41
1966 Nissan Caball C142
1967 Nissan Caball C240
1968 Nissan Junior 140
1966-1972 Nissan Clipper T65
1965 Nissan Cedric 130
1980-1982 Nissan Urvan
1970s Yue Loong Cedric 803 (91 PS/67 kW at 4,800 rpm)[2]
Also N230S, T40, forklifts and other machinery
