evildky wrote:I did not know this, I've only had first hand experience dealing with 85, 86 and 87, at any rate do what he says, he's the expert, and the speedo should be near the tailshaft on about every rear drive trans, I believe the s13-14 5 speed is the same as the na z31's save for the front case and perhaps the gearing
i'm sorry. I don't wish to undermine the moderators, but... as you know, I HATE seeing wrong information propagate throgh the internet...
SO....Please read: if you don't understand , I suggest you send the car to someone who knows better.
evildky wrote:the speed sensor for the digital cars attaches to a short speedo cable, there are no sensors on the bellhousing
Please don't confuse the issue. There is nothing mystical, magical, or confusing about this swap. He already has all the parts he needs.
1. pinion gear assembly. - came with the new transmission.2. speedometer sensor. - came with the car.
Take the speedometer sensor off the pinion gear assembly out of the old transmission. Unscrew the sensor off it. Screw this sensor onto the speedometer pinion gear assembly of the new transmission.
The only issue is whether or not the number of teeth of the new pinion gear assembly is correct. And that will depend on what model/year the new transmission came from. And all that means is you swap the actual pinion gear in the assembly.
