Nice work Tom!!!DrifterTom wrote:its 3:00 am so this will be quick. made 349.2rwhp at 6000 rpm at 18 psi and its still stupid rich.
i also had a boost spike, due to stupidity and hit 426.9 at 24 psi and way lean.
lots more to screw with and i will post some printouts of some runs when i get a chance (ancient computer that runs the dyno is being jewish)
woohoo for me
Might be stock cams so the power wouldn't make it up that far.Carl H wrote:rev it to 7 and you'll see 400.def impressive man but time for bigger injectors the 440's are not going to support fuel flow at those numbers, hell at 349whp thats about 400 at the crank which places you WELL above the 80% duty cycle of the injector.upgrade.
So thats your secret lolDrifterTom wrote: i have to jack the motor off .
