http://www.thecarconnection.com/marty-b ... and+Blogs)
It's currently 0* here. No way solar power could provide enough juice to melt the snow, without creating some sort of 32* icey disaster.nissangirl74 wrote:solar roads. How cool would this be?I hope they find a way to make this happen.
Read the article, homles. The whole thing is written toward deicing.AZ89two4Tsx wrote:^ That's not the point.
The point is that the roads will generate excess electricity. The idea is no way profitable or "smart" right now, but that is because of the lack of efficiency the current solar panels have. It is a step in the right direction though. I imagine once solar panels become more efficient, these little roads will start popping up in sunny states like AZ. As far as melting the snow....eh......
I'm curious to see how they would be maintained.
Ice be the problem. Take today; ~10*, tons of sun. Ice everywhere. Black ice too, the kind that sneaks up on you.AZ89two4Tsx wrote: Besides, when it's snowing, isn't there clouds? And when there's clouds, is there much sun? Then you have to bring batteries into the equation if it's not hooked up to the grid. Sounds pretty inefficient.
Average two-lane road? 24ft wide. A length a mile long, we're talking 126,720 square feet. Ice half an inch thick would come out to 63360 cubic feet of water. 7.48 gallons a cubic foot, 8470 gallons of ice a mile, basically. Ice at 0*C, Need to raise that 1*C. So 4.2 joules a gram. 3785g of water in a gallon, so 32058950 grams of ice on a mile of roadway, requiring 134,647,590 joules of power to warm it up 1*C. If I'm right, that's 37 kWh to raise the temp of a mile of roadway ice one degree.nissangirl74 wrote:I would think that in the areas where it snows it would absolutely be the main reason for using them. However, out here, the amount of electricity that could be generated would be phenomenal.
You're better at the math than I am, obviously, so work this for me. In theory, if the roadway is heated, the ice / snow would melt on contact, right? Would it take that much energy to keep the road clear or are you trying to melt from a dead cold start?Urabus GodofTraction wrote:Average two-lane road? 24ft wide. A length a mile long, we're talking 126,720 square feet. Ice half an inch thick would come out to 63360 cubic feet of water. 7.48 gallons a cubic foot, 8470 gallons of ice a mile, basically. Ice at 0*C, Need to raise that 1*C. So 4.2 joules a gram. 3785g of water in a gallon, so 32058950 grams of ice on a mile of roadway, requiring 134,647,590 joules of power to warm it up 1*C. If I'm right, that's 37 kWh to raise the temp of a mile of roadway ice one degree.nissangirl74 wrote:I would think that in the areas where it snows it would absolutely be the main reason for using them. However, out here, the amount of electricity that could be generated would be phenomenal.
A square meter of solar panels at the current level of tech produces about a kWh a day. The math just doesn't work. We'll break the speed of light before an economical way of deicing roadways via radiant heat is invented.
How about geo-thermal?Urabus GodofTraction wrote:We'll break the speed of light before an economical way of deicing roadways via radiant heat is invented.
We're talking the energy required to raise water 1*C. I don't know the math behind water losing it's energy in, say, 10*F outside air, so I can't tell you the energy required to keep water heated.nissangirl74 wrote:You're better at the math than I am, obviously, so work this for me. In theory, if the roadway is heated, the ice / snow would melt on contact, right? Would it take that much energy to keep the road clear or are you trying to melt from a dead cold start?Urabus GodofTraction wrote: Average two-lane road? 24ft wide. A length a mile long, we're talking 126,720 square feet. Ice half an inch thick would come out to 63360 cubic feet of water. 7.48 gallons a cubic foot, 8470 gallons of ice a mile, basically. Ice at 0*C, Need to raise that 1*C. So 4.2 joules a gram. 3785g of water in a gallon, so 32058950 grams of ice on a mile of roadway, requiring 134,647,590 joules of power to warm it up 1*C. If I'm right, that's 37 kWh to raise the temp of a mile of roadway ice one degree.
Even if I'm wrong (have Redcoupe or somebody who took a thermo class to the real math), the point is staggering.nissangirl74 wrote:Regardless, at the moment it seems unfeasible. It would be sweet though if they could figure out a way to make it work. I like the idea of using it out here to generate power. It would lessen our dependence on our other natural resources which can be stretched to the limit at times.
....so it would take a long a** time to make the money back, either way. They will become cost efficient, when all other sources have been depleted.Urabus GodofTraction wrote:Even if I'm wrong (have Redcoupe or somebody who took a thermo class to the real math), the point is staggering.nissangirl74 wrote:Regardless, at the moment it seems unfeasible. It would be sweet though if they could figure out a way to make it work. I like the idea of using it out here to generate power. It would lessen our dependence on our other natural resources which can be stretched to the limit at times.
The amount of power generated could be staggering, too. Assuming an impossible 100% conversion of solar energy into electricity, you're looking at a mile of roadway creating 70,640kWh a day. Of course modern panels are only about 20% efficient, so...
No traction in the rain?The process seemed straightforward enough: the company embedded LEDs in high-density glass pavement, as well as tiny solar elements to power them. The result?
