The entire world seems to have forgotten that there's more to an engine that fuel economy. In fact, it almost seems like people have started to believe the PURPOSE of an engine is fuel economy. It isn't.
Michigan State's team of engineers hope to have a car-sized 25-kilowatt version of the prototype ready by the end of the year.
25 kilowatts?!?!?!?! Are you kidding me. That's 33 hp. That's not "car sized." It's barely golf-cart sized.
Sorry, pipe dream ends here. 33hp would barely move a VW Beetle, let alone a modern safety-laden compact. If you can't package the power small enough, it doesn't matter how efficiently it sips at fuel. And when you're making miniscule amounts of power like that, you start to run into the problem of wasting much of that power just to carry the weight of the engine itself. It's idle operating efficiency might be 3.5 times that of a standard piston engine, but let's see it do that inside a 3,000lb hybrid. It's a pretty big leap from power-output efficiency to motive efficiency. Ion engines are fantastically efficient, but NOT suited to moving automobiles. This is no different.
Sorry, just like every other magic motor idea out there, it's not really what it appears to be. Set it on a table and it looks nice, but in practice it's not going to work.
There is more to automobile engines than efficiency. This applies even within the ranks of piston engines themselves. If you build the motor to provide MOTION and do it well, the efficiency aspect will fall in line on its own. It's a side-effect, a secondary attribute. It should never be the focus.
Researchers estimate the new model could shave almost 1,000 pounds off a car's weight currently taken up by conventional engine systems.
Bullpucky. Piston engines are almost entirely aluminum these days (unless you're Mitsubishi
). Even heavy ones don't cross the 400lb mark by much unless they've got lots of "extras" on their own. And if you're thinking "what about the transmission" well...you can't just have this wave engine hooked straight to the axle. Used as a generator, you're going to have electric motors, generators, batteries, etc. Used in a direct drivetrain you'll need a transmission. 1000lb my a**. Maybe if you put it in a Veyron and replace it with 2 motors and a 25kw generator, but then the Veyron's going nowhere in a hurry.
