simmode1 wrote:I'm curious as to what you N/A KA(de) gurus think is a realistic HP goal with the mods listed below. I'm hoping for 170whp or better. Extremely open to suggestions...
Power mods:short ram intakeOBX Header/downpipe w/ test pipe & EGR Delete3' catback exhaust (is this too much?)248/232 cam swapZ32 MAF (is this really needed?)And a good tune...
Drivetrain mods:Exedy stage 1 clutchFidanza 11 lbs flywheelaluminum drive shaftAltima e-fanCrank pully (what kind to get?)
I really should get wider tires too. I know that would help. Do you think 170+ whp is possible with this?
Modified by simmode1 at 12:29 AM 10/9/2007
I have pretty much the same mod list, only exception is that I do not have cams but I do have ignition mods (Blaster 2 coil, Taylor 8mm plug wires), OEM exhaust, SARD FPR, walbro 255lph fuel pump, and AEM EMS
I plan on dyno'ing before I install my turbo setup so I can get an idea of my gain. I don't have the EMS or FPR installed at the moment but I do not think I am putting down 170whp... maybe 170 @ the crank but IMHO you're aiming a bit high.
this spring we had a dyno day in KC here. a bone stock 97 S14 dyno'd at I believe 115 w/ the air filter removed.
I dont expect more than 160whp on my setup before I boost and thats with the EMS in the equation.
If you're not planning on going turbo I think that 3" exhaust is excessive. 2.5 should be just fine w/ a free flowing resonator (cherry bomb) and muffler. Also it won't sound like complete *** that way.
