a quick video of the 450zxtt in motion...
450zxtt
Car: 1993 450zxtt,1977 280z
what's up guys?a quick vid of my vh45dett powered z athttp://www.freewebs.com/axepower/ hit video...
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
God DAMN that VH45 sounds sexy...
That is so golden......!! I like the plenum sticking out of the hood... SEE MY SPIDER...
I want more!!!
450zxtt
thanks.i think it sounds good too. 450zxtt
Rex
Car: None
Yeah, I watched it last night as well, and that sounds/look very mean/nasty.
Looking forward to more updates.
574-240sx
Car: Nissans, Toyotas, Subaru
Awsome. That looks like alot of fun.
450zxtt
it is a lot of fun!much more torque than the vg30dett.i appreciate your remarks.450zxtt
95hondakillr
Car: 240s
Thats badass! Please post some mor, clearer footage
kimrober
Car: 1996 Q45t, 2002 Q45
Was it turbo boosted VH?, Z must have plenty room under the hood!Look awesome!
Rex
Car: None
kimrober wrote:Was it turbo boosted VH?, Z must have plenty room under the hood!Look awesome!
IIRC, and from the still pics, it appears to be a Twin Turbo VH45, or as some would call it, the beast within .
elwesso
2007 BMW M Coupe
I want to hear that thing redline.....
7000 RPM BEOTCH!
What kind of times are you looking to get out of it...?
450zxtt
as close as we can get to 200mph,i suppose.by the way,do you know of anyone with an available jwt ecu for an early q?thanks450zxtt
450zxtt
450zxtt site is temporarily down,we are working to get it back up...450zxtt
vicQ45
Car: 1979 Cadillac Eldog, 1987 Wagovan, 1968 Firebird 400
damn...exceeded bandwidth ill bet it sounds liek a beast!
John Dixon
Car: 300ZX-TT Z32
Slim, I've got a tuned Q45 code I could burn to a ROM for you, but TBH it leans out the top end which is probably the last thing you want on your setup.Because you've boosted it, you'll really need to look into expanding the maps then getting a good AFR from there, you'll be way past the max TP values on the stock maps I should think.I can mod my 300Z mapping stuff to work on the Q45 ECU if you want to have a fiddle. I've got the locations of most of the maps now. (was looking at them to convert them to my aftermarket system as a starting point for mapping)
450zxtt
i would love to have a fiddle at it...as you know,i was asking the guys at ztechz about this,but got no response.we are working on some prices for you and friday,as you can also see i have been trying to rally up some more interest ,parts will be a little less expensive if i can get more people involved...we would like to go cnc instead of more one- offs by hand.john,we need to burn some chips...450zxtt
450zxtt
way to keep the fire burning,jesda.thanks.450zxtt
elwesso
2007 BMW M Coupe
You do know that JWT makes a boost map that is MAF based.. Just call them up, explain what your using..... They said to me taht it is compatible with ANY FI setup, so long as the injectors arent overpowered, and stuff along those lines...
450zxtt
back when i spoke with them it was set for 5psi ,was $600 and the sales guy acted like i wasnt actually building my car.i know it is childish,but i wont be dealing with them.actually i would just like to raise the rev limit and remove the top speed limiter,then piggyback from there.we will go stand alone with the other motor(low compression).wanna keep playing around with q ecu based set ups on the stock motor w/stock internals...450zxtt
downtempo
Car: see biography
Oh my God! I think I wet myself
Amazing...
I can't wait to see how this story progresses.
Good to have you aboard, 450!!!
elwesso
2007 BMW M Coupe
450zxtt wrote:back when i spoke with them it was set for 5psi ,was $600 and the sales guy acted like i wasnt actually building my car.i know it is childish,but i wont be dealing with them.actually i would just like to raise the rev limit and remove the top speed limiter,then piggyback from there.we will go stand alone with the other motor(low compression).wanna keep playing around with q ecu based set ups on the stock motor w/stock internals...450zxtt
Im serious, JWT has all this stuff figured out... next time you call, ask for BEN..... salesmen suck, ben is one of the techs..
Falkdesigns
Car: 1998 Q45t ~ EXE
Daaaaaaaa#$!!! Sounds amazing bro!! That must be soooo much fun.
450zxtt
i understand and appreciate this remark.you are probably right about them having the stuff figured out.i will contact ben tommorrow.450zxtt
450zxtt
oh yeah,thanks for all of your comments450zxtt
elwesso
2007 BMW M Coupe
Theyre closed until jan 3.....
450zxtt
well,then,i will call ben on the 3rd.thanx,again.i assume you have a jwt ecu?450zxtt
elwesso
2007 BMW M Coupe
Yes.. I have the JWT, and when i go SC ill be using their boost map... Be sure to ask for Ben.....
JWT is golden, but they take forever to get anything done... Customer service sucks but its definitely worht the wait.....
450zxtt
elwesso wrote:JWT is golden, but they take forever to get anything done... Customer service sucks but its definitely worht the wait.....
so true.i used their ecu upgrades for my z when it was v6450zxtt
king4x4
Hello Guys, I am new kid to the forum but I joined up because of the profossianl expertise and knowhow of nissan engines and I am espacially interasted on the VH45DETT powered Z32 because you can get the VH45DE pretty cheap in the Region where I live (Dubai anybody) I even found a 2002 Cima Half-cut thats about 2500 US$ with every piece attached to it (even the headlights) and I am thinking of droping the engine inside of a 2002 Nissan Patrol one door (Look for it in the aussie forums if you want a pic or just ask for one) but I am facing a few problems mostly relating to the transmission (the engine compartment is big that they even drop Big Blocks in it) the transmission for the earlier engine (which is a TB45(s) carbruter) is very good and durabile and can withstand a chevy 454 easily.
The main reason for the mod is mostly engine related because the TB45 is a piece of junk (torquey yes but not that a high HP only 200hp).
I found out the service manuals for both the Q45 2003 & z350 so the wiring is not a problem & I am just asking for any helpful info for the swap.
Oh yeah a VH45De for a 94 model costs about 450 bucks with the transmission.
