a quick questions before i purchase everything.......
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
ok, so i will be purchaseing turbo stuff for my s13 ka24de to complete the kit and i already have some of the parts.i will be running.......
T25 turbo from red topBlitz 3in downpipe sr20detmegan elbow sr20detmegan bottom turbo manifold KA24DEgreddy type M FMIC for s13 sr20dethot pipe for s13 sr20detstock SR 370cc injectorsafc neoearl's return/feed oil line complete kitstock MAF for now
im not too sure what kind of boost controller & turbo timer i will be running. anything i might be missing????
my question is will all the parts like FMIC,elbow, d/p etc will have a direct fit????
i heard i might have to weld or add an extra peice to make it fit perfectly because it might be a little off. is that true????
also how does that set up sound????
LMK! thanks
sunnys14
Car: S14
ditch that safc and save up for an enthalpy ecu tune. safc just sucks and i wouldnt recommend it. but if you want to use it, i would retard base timing 4 degrees and run 8psi on the t25 because anymore boost and you cant control timing enough.
ooks like youre missing a walbro fuel pump to feed your injectors and a wideband sensor for you to tune with.
FMIC should fit if you use a slightly longer coupler for the throttle body.
setup is pretty good, just get a good clutch for the bump in torque that youre gonna get.
240sxvaj
will the stock fuel pump do the job????and what is the wideband sensor for?
sunnys14
Car: S14
stock fuel pump will do the job, but i dont know how long it will hold up. just spend the extra 85 bucks so you know for sure your fuel pump wont crap out on you.
a wideband sensor is for tuning. it shows your air fuel ratio so you can use with the safc to tune. how were you planning on tuning the safc without a wideband? just mess around with the numbers? thats a good and quick way to blow up your motor.
240sxvaj
how much does the wideband sensor go for????
sunnys14
Car: S14
PLX m300 widebands ive seen go for $280 on ebay
240sxvaj
kool. thanks
what about the aem one? isnt there one for under $250?
eazye2000
Car: S13 KA-DET
Check this out from one of our sponsors, Injected Performance. zerothread/125870
He sells the AEM WideBand for 250$ shipped, and the Walbro 255 HP with the install kit for 85$ or 88$. I also got my KADE Koyo from him for 265 shipped.
Awesome sponsor, and I got alot of things from them. Talk to Marty.
240sxvaj
eazye2000 wrote:Check this out from one of our sponsors, Injected Performance. zerothread/125870
thanks!
480sx
Car: 1996 Pearl White 240sx
Zeitronix owns all.. Check them out, they spank the AEM unit for sure. Cheaper than a LM-1, and a much faster sampling rate.
However never used the PLX devices, they seem to be expensive for what you get. You buy one, and the company's idea is that you will buy a set of their devices to daisy chain together and get a full gage setup.
Zeitronix if you have a laptop, the data logging software makes tuning a snap.
Florida240sx
Gotten a lot of my parts through Marty at injected. I got the innovate lc-1 xd-1 combo.
240sxvaj
would it be alot better if i had a tune enthalpy ECU?
or go AFC NEO w/wideband sensor?
which is alot better and cheaper to go with?
i know about the ecu that i will have to send my ecu for them to tune it with whatever set-up i am running but then which is alot better????
i done my research on the ecu and afc but then many people have many different opinion.
LMK!
thanks!
Florida240sx
Send your ECU to enthalpy. Trust me one this one. How much you looking to spend on a turbo setup? I just took mine off my car to go a different route. Was an IAP kit.
kpc_0721
Car: 1991 240sx hatchback
Were can I get info on enthalpy tunes because I want to go with an enthalpy and run a safc for fine tuning?
coolbone28
Structure240sx
enthaply is a great way to go
i personally had no issues with my safc for the years that i had it. good chance i will run another one on the new car for fine tunning since enthaply does not offer a tune for my setup
lrb_2000
Car: '91 Nissan KA-T hatch
Yeah. I ran a SAFC II and wideband on my car for quite awhile, never had problems. I ran a good 14psi with it, and set timing to 16btdc.
I'm going with a enthaply ecu this time though. I'm too lazy to tune from 0 again. lol.
240sxvaj
lrb_2000 wrote:Yeah. I ran a SAFC II and wideband on my car for quite awhile, never had problems. I ran a good 14psi with it, and set timing to 16btdc.
if i was running the enthaply ecu tune would i need any other things? liek widebands? etc.......
neverlift
just me but a rom tune owns the fizuck out of an afc setup.
Although alot can be done with an afc as for fine tuning. So if you can afford both, get it.
as for wideband man I swear by my plx, no issues with it whatsoever.you can put the plx smafr with a cheapo summit a/f ratio gauge and rock a wideband for under 250 shipped....
WDRacing
I like my LM1 wideband. Datalogs afr's and rpms for ya...
Florida240sx
Before heavy boosting you need ot go to a dyno with your enthalpy tune or have a wideband borrowed. Just to make sure everything is working correctly.
240sxvaj
purshase some parts already
but then still need the return/feed oil line kit
which brand name makes it for the KA24DE t25 bottom manifold????
lmk! A.S.A.P
thanks!
sunnys14
Car: S14
http://www.jgstools.com/turbo/index2.html
they make a oil line kit for about $80
240sxvaj
sunnys14 wrote:http://www.jgstools.com/turbo/index2.html
order it already
still need sr injectors thoughand afc, wideband, & guages and a intake kit for the t25. what kind of pipe should i use for the intake????
Modified by 240sxvaj at 3:25 PM 10/3/2007
Modified by 240sxvaj at 3:27 PM 10/3/2007
240sxvaj
ok, got a good deal on a used Greddy e-Manage.it came off from a 300zx z32.comes with harness. everything i need to complete it.what will be needed since im going ka-t????
480sx
Zeitronix data logs RPM, Boost, EGT, AFRs, and a 0-5 volt user imput. I use this for my MAF, to make sure its not maxing out. You could also use a BMW knock sensor for it, they are much better than the Nissan bosch units, that have alot of false positives. Also has a 7 times faster sampling rate than the LM-1.
Of course you wont be able to datalog EGT and Boost without the senders, but its nice to know you can always upgrade it when you feel like.
Ontop of that, you can get a warning light/buzzer that can give you a warning if any of your values get out of whack. Say, you want to set a two stage alarm, say, if your AFRs are higher than 12 and your boost is over 10. Or whatever, you can mix it up.
I swear by my Zeitronix unit ^^
240sxvaj
im lost here.
i was wondering what else will be needed to install the e-manage, besides takeing it to the shop and tuning it.
your talking to a noob here.
LMK!
thanks
neverlift
its ok. you just need a wideband, you probably dotn need all the other things they are speaking of since you dont know. Get an w/b o2 and learn what its telling you.
the emanage IDK try their forum...
240sxvaj
im gonna ditch the e-manageheard it was gonna have problems later on in the future from a shop
now, i was wondering if i can be able to run my turbo kit with out any upgraded injectors?do i need the other guages instead of the boost gauge?will my car run ok with out any tuning and injectors?what kind of raceing battery will be good enough to bump a AMP and 1 SUB?is westco ok? or optima (how ever u spell it)also what size of injectors should i run on my set-up?
lmk!
my set up is.......t25 came off from redtopgreddy type M FMICJGS return/feed oil line kitunknown brand bottom manifoldmegan elbowautometer boost guageblitz down pipehot pipe with HKS BOVregular autozone filter
i think im forgeting some stuff but then cant remember it
everything is pretty much bought except the AFC, wideband and injectors
thanks
Modified by 240sxvaj at 1:49 PM 10/19/2007
eazye2000
Car: S13 KA-DET
You really really need to get injectors man. If not, you need to throw in a walbro fuel pump, and get an 8:1 FMU or something. If not, you're gonna pop that motor if you start to boost it. Save up 100$ or something and get some SR injectors. Hell, even if you don't have an SAFC, it's better than not having enough fuel. Too much is better than not enough. I'm not sure if it will idle well. I've half ***'ed a few things, but not that kinda stuff.I'll see what I can find for cheap... I may be heading to the junk yard today. I'll let you know what I come up with.
