A quick Question.
newbitoengines
Car: looking on slavaged
Hey guys i been browsing these forums alot and you guys are really cool. NEWB yes, so all comments are welcome. ok so i been looking into buying a used G35 Coupe. I really dont care on how many miles it has on it. so if i do decide to swap the engine. i want to swap to these certain engines. all Nissan. 2009 GTR Engine. 2009 370Z Engine. OR and 2009 G37 Engine. Is it possible. to get all of these three? (NOT ALL AT ONCE) lol. and i have found a site that sells all three engines for dirt cheap.
biggie
Anything is possible, with enough money.
That said, GTR would be near impossible, espeially given the transmission/drivetrain issues.
Would assume the VQ37 would fit and mounting would be pretty close to stock, but wiring is going to be the issue on those.
Much easier to rebuild a VQ35, then add boost if you want more power.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
+1 to what Biggie said
you can do lots of things - but in the end your best route it you keep the engine in the Nissan family is to stay with a stock motor and just build it stronger or build for boost. No sense doing anything with the VQ35HR/VQ37HR or VR38TT motor as the cost to install will far outweight the advantage/initial cost of the motor.
You can get a spare VQ35DE (stock motor for 03-06) and build it to make it much stronger if thats what you are looking for
newbitoengines
thanks for the replies guys..and another question..i always loved the performance monitor/navigation system on R34 and R35..is it possible to have that exact thing on the G35? and also how would i get all the best horsepower out the G?
tollboothwilley
navigation can be found but its very different from the GTR. To have a similar setup you will spend a grip on sensors/gauges or a screen that can integrate with the sensors.
HKS makes the CAMP2 which will do this but its not cheap - looks super sexy though.
joe603
Car: 2014 Durango R/T
Also remember that if you change the engine, you'll need to change the wiring harness. You may be better off using the same engine, but built up with forged internals and go forced induction. Twin turbo G's are HOT!
