a quick question
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
would number 5 on this diagram be what a chilton would call the gasket? i'm getting close to all the replacement parts i need
http://www.trademotion.com/par...gid=1
JeromeS13
Car: 2008 Subaru Impreza STI
I'm not really sure why you're using a Chilton's Manual. However, the FSM does appear to call it a gasket.
underground57
Car: '93 240sx fastback, '04 Frontier
It says its a spring seat, so I wouldn't know why Chilton would call it a gasket. A gasket is something that is placed between parts to seal gas or fluid. A spring seat is what holds the spring on the strut.
JeromeS13
It also calls number 7 a spring seat. And, you can't have TWO upper spring seats. So, it appears that number 5 is the orange 'gasket' that goes between the top strut mount and the body. It's only purpose is to keep metal off of metal and squeeking.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
thanks all, especially jerome. the reason i am using a chilton is because i don't have an FSM. the chilton was cheaper and i thought it would serve more purpose
underground57
I stand corrected. That pic is misleading and mislabeled.
underground57
Here is a close up from the FSM.
JeromeS13
http://www.zeroyon.com/index/content/view/24/47/
You can download a copy of the FSM for free.
Happy Birthday.
-Jerome
underground57
Jerome, thanks for posting that. I couldn't remember the site, so I took a picture of the hardcopy.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
weak sauce, my cpu doesn't like that like, it instantly cancelled it as i tryed to download it
underground57
Did you try and save the link? You need to click the link and save the correct FSM It should be a zipped pdf or something.
