You aren't using the clutch to stop the car, you're using the engine.fatboy wrote:using clutch to stop car is a crappy idea......
If you drive normally you won't. The biggest advantage of MMs is fade resistance. OE brake pads are poo on a track because they fade like a *****.GrubyFngaz wrote:I think I'm just going to get some OEM ones from the dealership, they last a lot longer and I never could tell a difference with the MM anyways.Josh
