Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Sun Jan 01, 2006 5:57 pm
A few good factoids here,
Correction to: "softer tire needs a stiffer sidewall to support it"...
and:
"Lets see if I can manage to make since with words....if the tire is too narrow for how soft the composition is, the tire will roll off of the rim due to the side wall not giving enough support. If you widen the tire while retaining the same side wall height, you will decrease the aspect ratio allowing the sidewall to support the weight." This is incorrect;
The bladder inside of the tire suports the weight. Aspect ratio and compound can be tailored completely independantly of one another. The reason you see softer compounded tires in lower aspect ratio tires is because they GO ON CARS DESIGNED FOR THE STICKER COMPOUND. Sifewall stiffness/rigidity is also independant to some degree of load bearing capacity also...and FYI, the bead structure is how the tires stay attached..compund has nothing to do with it. Look at the drag picture..thats a high-aspect, soft compound tire..running at 3psi..how does it stay attached? THE BOLTS ON THE BEAD "bead lock"... (for why they run 3psi, look down to my next post)
ok, next issue.
The first post in this was neat, good illustrations.
Also, the "siping" being better on wider tires..the ammount of sipes present on the ground, and wet traction to a degree, is a function of tread design, not size. you have 3 square inches of contact patch, regardless of how wide the tire is..the tread design will determine how much siping gets on the road.
Likewise, treadlife is more a function of tire design and compound than width and size....
I'll be doing a ncie write up on this stuff once I finish...Until then, I'm going to lock this for future editing..
-Chet
