cls12vg30 »
https://forums.nicoclub.com/cls12vg30-u11732.html
Tue Dec 16, 2003 6:40 pm
I installed dual electric fans from a '91 Stanza on my '88 200SX V6 over the summer. They've worked out very well. My radiator is a bit weak, and the two fans cover much more radiator area than the one original clutch fan, so the car runs much cooler in traffic.I paid $50 for the whole fan setup at a junkyard, about $20 for an adjustable thermo switch at Advance Auto, and the only other things I had to buy was a bunch of wire, various connectors, and plastic tubing to contain the wiring and make it look nice.I designed dual control circuits for the fans. See originally my S12 had the clutch fan and a secondary electric fan right in front of the clutch fan, but the switch for the electric fan gave out awhile back, so I had mounted a toggle switch on the dash to control it. I got used to controlling that fan and got to enjoy the little extra bit of control, so when I tore the old fans out and went with the dual electrics I wanted to keep the switch. The Stanza fans have three speeds, I did not use the lowest one. I designed the fan control circuits so that when either the thermo switch or the dash switch is on, the fans run at medium speed, if both switches are on, the fans run at high speed. Both control circuits are wired right into the battery. The circuit with the dash switch has a relay, and the switch is wired into an ignition switched circuit, so that circuit can't run with the engine off. The thermostatically switched circuit can. (Since all the wiring for that circuit is under the hood, and the thermo switch's amp rating is more than enough, a relay wasn't really necessary for that circuit.) So if the engine gets warm enough to kick in the thermo circuit (which it usually does around town, unless it's really cold out), the fans will run at medium speed for anywhere from 3 to 10 minutes after engine shutdown. This is a bonus, and many newer cars do this stock, because of the large spike in the radiator temperature that occurs after you shut the car off and the coolant stops circulating.Wow that was pretty long, I guess the point is you can get a good dual setup from a Nissan for less that a hundred bucks. The Stanza that the fans came off of used a KA24E, and the fans have proven to be plenty powerful enough and move enough air even for my VG30E.
