A question of cooling FMIC
greensparcs
ok im curious as to what intercooler to get when i have the money to play around. so here is my question what intercooler do you guys reccommend for my 90 tt? front mount side mount and any preference on brands? and what all is involved in installin it and also if its front mount what do i do to make sure my radiator is getting enough air flow? green, (in more waysthan one )
greensparcs
so no body?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
some info about your car and set up might help, I have a vertical flow 18 x 9 x 3.5 treadstone in my 71 240Z wtih the L28ET and a T3O4E, I had a cheap ebay 18 x 12 x 3 crossflow and it sucked, my Z32 runs stockers
Outkast
Car: 05 Titan 4WD CC, 00 Maxima SE 5spd, 91 TTZ
Sidemounts are more then enough for stock set up. Z1, Ash, and Greddy are just a few good upgrade choices.
Now 99% of Z tuners will bash the front mount cause it will actually have a slight pressure drop but for higher boost applications it's actually good. Some will also say it's bad cause it'll make the car run hotter but it's not true either. I run one on my TTZ and haven't seen a single tempature change.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Unless you're going very heavy into a build side mount intercoolers will be more than enough for you. HKS, Greddy, ARC, or similar will work great for you with stock or upgraded turbos. I don't really recommend a FMIC unless you go all out. If you do, and you go FMIC, I recommend HKS. Many of the "affordable" fmic's on the market for the Z32 are junk. Make sure you educated yourself as much as possible before spending your cash on one
evildky
06 Nissan 350Z GT
duh I wasn't even thinking that I was in the Z32 section, I know of at least one car putting 500whp with stock intercoolers, I have heard of some people complain of running hot with the front mounts as it restricts the air to the radiator
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
evildky wrote:duh I wasn't even thinking that I was in the Z32 section, I know of at least one car putting 500whp with stock intercoolers, I have heard of some people complain of running hot with the front mounts as it restricts the air to the radiator
Stock intercoolers? Do you mean sidemount intercoolers? I've never seen anyone make over 400 on stock IC's. They become heatsoaked and ineffective pretty easily.
Florida240sx
Fixin to do my Vg swap in my s13 vert I was going to switch to fmic.......... Plan to run stock turbos and up the boost to 12-13..... Keep Sidemounts until I have a built engine??
evildky
06 Nissan 350Z GT
nope, stock I/C's, although he's not quite to 500whp, he was having some fuel issues wiht the vafc (too lazy to go full stand alone) it was pig rich up top and I think he maxed like 480whp, we have another dyno day in november so we'll see if he made it to 500whp yet
greensparcs
so then maybe something like this would be ideal with the upgrade piping and some JWT 700BB Turbos from JWT?
evildky
06 Nissan 350Z GT
I wouldn't even consider a front mount unless you had upsized turbo's, I still think the upgraded sidemounts are better, too many ricers just want a front mount for the sake of show, the only real benefit I see is the potential to shorten the piping
