SHIFT_COUPE wrote:It sounds like you really don't need a new router. I wouldn't worry about a gigabit connection on the router since you already have a gigabit switch. Your'e really only going to use that one connection from the router to the switch where your other devices will branch off. This is where you will see the gigabit speeds, not through the built in switch on the router. I know that might sound convoluted! The router is only issuing the IP addresses through DHCP, no local network traffic will go through the device.
If you're dead set on getting a new router I would go with any Linksys product. I've had solid experience with every device I have had from them. If you were to go Gigabit and Wireless N you might spend $80 or so for the most basic of their devices.
Ah, I think I confused you a bit with my poorly worded earlier description! Here is how I have things hooked up today - pardon the
extreme geekiness in this entire post/thread
Earthlink <---> ZyXEL P-600-R Modem/Router <---> Netgear GigE Switch <---> D-Link 655 WiFi Router <---> Home WiFi devices.
The ZyXEL and Netgear are upstairs in my home office, and the D-Link is downstairs in my family room (my whole house is wired up to a patch panel in my upstairs office, so the connection from the Netgear to the D-Link is via CAT-5e Ethernet wires).
Separately, in my home office, I have a laptop docking station and the GigE port on the dock is connected via a CAT-6 patch cable
directly to the Netgear switch. So, when upstairs, my laptop does not use WiFi at all - it is a wired Ethernet connection to the ZyXEL and on to the Internet (since the Netgear is just a switch). Thus, I can also easily configure the ZyXEL from that docked laptop (although I could do it through the D-Link too, I don't like doing firmware updates anywhere using WiFi):
Earthlink DSL <---> ZyXEL P-600-R Modem/Router <---> Netgear Gig Switch <---> Lenovo Laptop dock.
The ZyXEL DSL modem/router provides DHCP services to everything connected to it (specifically, the D-Link and my laptop
when docked - the Netgear switch is transparent, of course).
The D-Link provides DHCP services to any WiFi devices talking to it - separate IPv4 ranges, of course, to prevent collisions). There is nothing wired connected to the D-Link switch ports (it has four of them).
Here are the two alternatives as to what I am thinking of doing (one with the 6121 and the other with the 6580). The laptop docking station
continues to stay connected to the Netgear switch at all times with the same CAT-6 patch cable:
Alternative 1:
Comcast cable <---> Motorola 6121 modem <---> NEW non-WiFi firewall/router <---> Netgear Gig Switch <---> D-Link 655 WiFi Router <---> Home WiFi devices.
Alternative 2:
Comcast cable <---> Motorola 6580 router (if WiFi can be disabled) <---> Netgear Gig Switch <---> D-Link 655 WiFi Router <---> Home WiFi devices.
With Alternative 1, I would need to buy a new non-WiFi router too and was looking for recommendations for it. Something good enough to do GigE speed firewall/routing performance
and it must have good firewall settings controls, DHCP server, time-sync to an external site via NTP, easy DNS configurability (I use
http://www.opendns.com for home protection), etc., etc., etc.
Yes, I will explore Cisco/Linksys solutions for this new router if I go with Alternative 1, since the Motorola 6580 Users Manual does not impress me too much ... yet. The device
seems to be more limited than I expected from a good router, but I may need to just read more about it.
Thanks for the responses so far, folks!
Z
