Import_Ant »
https://forums.nicoclub.com/import-ant-u16968.html
Mon Aug 08, 2005 3:30 pm
on the S13 DOHC wiring harness the O2 sensor shows as only having 1 wire. that is pin 13 on the ECU and it's white. The PLx-300 has two analog outputs, the white and the gray wire but since the ECU only has input for one, I'd treat the gray wire as an auxiliary. hopefully you'll get a reply soon but I don't see anywhere to connect it (I am guessing they provide more than one in case you want to run a narrowband input to a standalone or piggyback so you dont have to use one wire for multiple items.
if you're running an S14 or S13 SOHC let me know I'll dig up the FSM for that car to verif the o2 sensor wire color at the ECU.
