a question about brake pedal feel
xagna
The brake pedal feel changes in relation to ebrake tightness. When e brake is tight, brake pedal needs more pressure to work. When ebrake is loose, brake pedal works nornal or close to normal. Any one know why this is happening?
s13sr20chris
that is bizzare. what kind of car? do the fronts or rears lock up first if you stop hard?
xagna
Locking up doesn't happen.
s13sr20chris
if you cant lock them up then something is really wrong. either all your wheel brakes are malfunctioning(like sticking calipers or collapsed hoses) or you have lots of air in the system. i dont know how that would cause the pedal to drop when the ebrake is on. however, its more serious than that.
Red coupe
Car: 92 Nissan 240sx Coupe
my 92 s13 base does this as well...I thought it just had somethen to do with the ebrake acting on the piston itself. With the car off if you press down on the brakes and lift the ebrake you can feel it in the pedal...
