A progressive humming noise as I drive.
Yogi'sQ45
Car: 1994 Q45
I have a 94 Q45, and as I am driving there is a humming noise that seems to be coming from the back of the car. I replaced the rear tires, they needed replacing anyway, but no change. Any ideas? Thanks, Mike
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Nest of bees in the trunk?
Think about your fuel pump. Read Tangalora's excellent post.
Don't drive until it's diagnosed correctly.
Q45tech
Progressive like with speed increases...............differential, wheel bearings?Vehicle mileage and maintenace intervals of replacing diff fluid?
Usually diff and wheel bearings last ~~200k.
goody90q45
Car: 1992 Infiniti Q45 (sold)
maxnix wrote:Nest of bees in the trunk? Think about your fuel pump. Read Tangalora's excellent post.
The fuel pump is in the gas tank which is behind your rear seat. Open your trunk and listen. At idle, if you hear what sounds like a swarm of bees coming from inside the gas tank it's your fuel pump. You'll need a new fuel pump and probably a Fuel Pump Control Unit (FPCU). Both are easy to replace and the DIY steps are in Tangalora's post which you will find archived. Good Luck.
Yogi'sQ45
Car: 1994 Q45
Thanks for the responses! Yes, the humming noise or pitch increases as the speed increases and vise versa. I don't hear until I reach ~15mph. It has 142,000 and I've had it for 2 1/2 years and have not done anything to the differ... or wheel bearings. Thanks again for the quick response. Mike
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
No fluid change?
Q45tech
The next step is to place it on a safe 4 post /point lift and drive the wheels to speed whicle listening under the rear with your automotive stethoscope to identify the exact NOISE SOURCES.
Make sure diff is refilled with new lube first.
Failure to drain and fill diff every 2 years or 30k is a sure way to spend $3,000 faster than you should by replacing diff.................eveny iffy high mileage junk yard units are $300-$400 plus installation and who knows if they will be better or fail soon.
qsiguy
Car: 1994 Infiniti Q45 Turbo
While not in the rear of the car, the transmission mount can cause annoying hum. The sound would change with speed/rpm and when I replaced it along with the related exhaust mounts the hum was gone.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
It could be the timer of a bomb planted by one of your enemies.
