mightyversa »
https://forums.nicoclub.com/mightyversa-u119557.html
Wed Feb 04, 2009 3:36 am
Ok, off the bat that I dont even need to think of are:
Collapsed Brake Hose (From Caliper to Banjo Fitting)
Defective Calipers (Cant really see this being the issue because the brake fluid would have to be dirty to leave an internal seat for the piston not to push all the way back on evacuation of brake fluid)
Pushrod adjustment out of wack on the Brake Booster or maybe even a leak on the inside half of the brake booster.
I dont know if the V is equipped with it, but a deffective Brake Proportioning Valve can cause issues like this
Does it have ABS, if so:
The ABS motor could be screwing up I cant think of anything else off my mind, but hope some of these are the problems cause if they aint, looks like some screwed up brake issues!
