gtrisfun »
https://forums.nicoclub.com/gtrisfun-u82095.html
Thu Nov 29, 2007 4:46 pm
why not get a set of surface mount tweeters? they would come with bezels that sit about 3/4" (1.5-1.75cm?) out from your mounting point. one advantage is that you might be able to aim them better than the stock positioned set. then paint the mounting bezels to match your A-pillars (if you're trying to get a more "stock" look).
i'm not sure on the impedence for the front set of speakers, you might not be able to just add a set of tweeters to the current wiring. on the 00-06 sentras, the speaker configuration is same as the versa, the front set of speakers in the 4-speaker set is at 4 OHMs each (as well as the rears). but in the 6 or 7 speaker set, the front output splits between the door speakers and the A-pillar tweeters, but at an uneven impedence (i think around 1 OHM for the tweets, 3.5 OHMs for the doors). friends of mine who have changed out the door speakers without changing the tweeters find that the tweeters end up blowing out.
it may end up that you might need to remove the door speakers and get a set of aftermarket component speakers (midrange speakers, tweeters, and crossovers). if you can afford it, it may be a more worthwhile option to keep in mind.
