Might have to do what you said. Just mold it. How did you attach it to the pillar? Did you have to glass it in to fill up the difference in material?mpbclutch33 wrote:... I bought a universal one and used a heat gun to soften the plastic and mold it to the pillar and then painted it to match. Turned out pretty good.
IF f I didn't have the Bose Navi but A+ for effort! I think putting it on the pillar will be the only option.mpbclutch33 wrote:I am not sure how that would be accomplished given the conture of the AC Vents, but you could replace the AC Vents like some of the Turbo'ed A/C's have doon. The other option is if you have a Single Din aftermarket Stereo, there are dubble and triple gauge pods that fit into the pocket area.
I think you're right...too freakin ricey08altima35 wrote:most tuner enthusiasts are getting away from the pillar gauge cluster because so many how shall i put this one...wannbe ricers that watched the F & the F too many times and have no need for gauges to monitor a stock set-up. If it's your taste than go for it, but there are other options.
