i know this is a old thread but how the hell you have been able to remove and REPUT the 2 little screw in 15min ?rico05 wrote:Wow...I did it in 15 minutes. I got a 1/4" drive ratchet with a 1/4" socket. I then grabbed a philips head bit and viola! Got the bolts off with the rail still on.
I cutted the hose and pull off the fpr. I'm not able to put the new one without kink the rubber tube when i try to loop it around.Ca_Silvia wrote:Just cut the hose, pull off the FPR then re-install the new one with a new longer hose. You have to put a longer hose on anyways...
