A NISMO... Rogue?
Your stop for everything on Nissan's performance brand. Whether you're looking for info on the new Sentra NISMO concept, the GT-R NISMO, 370Z NISMO, or just some of the many NISMO branded parts - You're in the right place.
RicerX
Car: '20 Titan Pro4X
http://www.autoblog.com/2013/11/30/niss ... mo-coming/
The Qashqai is definitely getting the NISMO treatment overseas, which means that it's quite possible the 2nd gen Rogue could be massaged by the NISMO arm.
What do you think?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Severnvalley Motorsport shows off their Nissan Qashqai-R
Britain's Severnvalley Motorsport is wrapping their Nissan Qashqai-R project.
Drawing inspiration from the Juke-R, the Qashqai-R is Frankenstein-like creation that is part Qashqai and part GT-R. However, unlike the 2012 GT-R donor car, the Qashqai-R will have an upgraded twin-turbo 3.8-liter V6 engine that produces 1,000 bhp (745 kW).
To keep things under control, the model will be equipped with a number of upgraded components including a KW coil over suspension, Eibach anti-roll bars and a high-performance braking system.
The car is a hybrid of a Qashqai+2 360 and an R35 GT-R, using the complete running gear and floor pan from the R35 has enabled us to take the Qashqai from it’s standard engine and running gear to the identical set-up that the R35 uses (and more, much more) !
Return to “NISMO”
