fodojonny »
https://forums.nicoclub.com/fodojonny-u97534.html
Thu May 22, 2008 6:18 pm
ok kids, here's the deal. I'm new to the forum but I'm an experienced mechanic. I own a 1990 s13 and recently blew up the e motor. I've been plotting my de swap anyways so it didn't hurt to bad. well I have a de motor anyway, actually two but one is good to go other than a little resealing. I'm planning on using my sohc wiring harness and ecu along with all the accessories from the e motor on the de. how is this possible you might ask. simple. I've been studying the cars I've been working on and swapping parts between the two different motors. my alternator brackets from the single cam fit on the de and so does my a/c bracket. it will look like the belt set up on the sohc motor or the frontier's ka24de. the only exception is p/s will have to go because of the different manifolds. most of the plugs are the same on the manifold I'm using (it's from a 92 s13) the iac plugs, oil pressure sending unit, coolant temp sensor and sending unit are all identical the only thing I'll have to wire are the injector plugs and the dizzy. I'll even be able to use the 90's brake booster vaccum line.I'm thinking I won't have the problem with switching tachs like this. this is still a work in progress and I'm sure there will be a snag or two in the swap but so far things are looking promising.
Modified by fodojonny at 12:23 AM 5/26/2008
