A new GOODIE for my Q.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Yes, thats right. Espilir springs for G50. Compliments of Robert, aka audiovisiony33.
He got the espilir springs for the Y33's and he got the ones for the G50 for me to try. If I like them, which I dont see why I wont, maybe he will bring a bunch over.
I got them for cost, so im not going to say what I paid. Hopefully im going to install them in the next few weeks....
The quality seems to be amazing, and they arent progressive rate springs so hopefully this will improve my handling qualms ive had with the car this past year.
The spring rates are 4.6 kg/mm(F) 4.2 kg/mm(R). I dont remember what the stock spring rates are but thats slightly stiffer.
qsiguy
Car: 1994 Infiniti Q45 Turbo
You are using cali customs currently aren't you? You think these are going to be better? How about ride height? Think they will be lower/higher/or same?
Do you have a guess on what you/they will be able to sell them to us for?
elwesso
2007 BMW M Coupe
I think robert said about $350 shipped, minimum 10 orders. maybe less? Theyre pretty expensive in Japan.
The ride height should be about the same, at least i hope it is. I'll have to check the chart.
I think theyll be better for handling since theyre not progressive rate springs. But the cali-customs may bea better choice for a daily driver sort of thing.
elwesso
2007 BMW M Coupe
http://www.espelir.co.jp/sp%20...l#q45
Says 40-45mm front and 30-35mm lower
So about 1.5in F and 1.2R.
Rex
Car: None
elwesso wrote:http://www.espelir.co.jp/sp%20...l#q45
So less lowering than the Cal Customs and they're not progressive ... I'll be interested in your "review".
It would be nice if we could find a decently priced coil-over offering/set-up.
Q45man1
Car: 2002 Q45, 1994 Q45
Wes,
Let us know of your evaluation. I would be interested too in sigining in if the results are favorable.
elwesso
2007 BMW M Coupe
I really REALLY like the stance my car has with the cali customs.... but if it improves the handling im all game...
Tech... what do the stock Q springs have in terms of spring rate? My main concern is the tokico blues not being able to handle these bad boys...
96Qowner
Car: 1996 Q45
elwesso wrote:... what do the stock Q springs have in terms of spring rate? My main concern is the tokico blues not being able to handle these bad boys...
146lb/in and 123lb/in = 2.63Kg/mm and 2.20Kg/mm (?). "Slightly" stiffer, ya.
elwesso
2007 BMW M Coupe
holy crap these bad babies are about 2x stiff.... I dont think the tokico's are going to be able handle these guys real well, so we'll see.
96Qowner
Car: 1996 Q45
Might wanna check my math. But I think it's correct.
audiovisiony33
Car: 1997 Infiniti Q45
Any good news on installation?
Q45tech
At these stiffness levels the blues might last 15k vs 60k with old Eibachs or 80k stock.
Doubtful that blues can even partially control rebound especially on rear good luck.
Pretty painful in more ways than one to reduce body roll by half 1.75" vs 3.5".
Can you supply the unmounted spring length so we can calculate the natural spring frequency.
Careful about too large or stiff rear sway bar [stiffer than 20mm] as the published spring stiffness will decrease the rear understeer by 9% vs oem.............
4.6/4.2= 1.09 vs 146/123= 1.187
elwesso
2007 BMW M Coupe
audiovisiony33 wrote:Any good news on installation?
i didnt get a chance to install them, i tried but i couldnt pull it off wiht the equipment i had. im going to do it sometime this fall i think.
qship96
Car: 1996 Infiniti Q45
[QUOTE=Q45tech]At these stiffness levels the blues might last 15k vs 60k with old Eibachs or 80k stock.
WoW............ decreased ride quality and the need to spend the time and money to replace shocks every 15,000 miles,what a price to pay so your car looks kewl ! What a joke!
dj tantra
id be obliged to conur
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
qship96 wrote:
Q45tech wrote:At these stiffness levels the blues might last 15k vs 60k with old Eibachs or 80k stock.
not looks PERFORMANCE
cccpman
Car: 1990 Q45
Everyone knows the higher performance you get the sooner parts will die out. This is no different, he wants a performance suspension thats what he has this for, granted its a little bit shocking how quickly it will wear some parts but im betting it would be quite a noticeable change
95q45_97cobra
Car: 1997 Ford Explorer (5.0 GT40 Cobra), 1992 Infiniti Q45, 1995 infiniti Q45 1985 Nissan 300zx Turbo,19
hey wes, man u should take some new pics of your Q.... love to see all the work that is being done.!!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Well, obviously we need some accurate measurements to determine if these will even work on the street. Even 50% stiffer wouild be near terminal go kart stiff. Even with custom shocks.
Modified by maxnix at 12:07 PM 1/29/2008
qship96
Here is the old thread about Espilir spring rates being too stiff!!!
qship96
96Q owner, here is the original thread on the lowering springs you mentioned in the now "LOCKED" suspension thread-lots of info!
