Recently I picked up a pair of JL 10W6v2's. I still plan on mounting them in that small space behind the inner fender just outside the cargo organizer. To do this I have to cut (gasp!!) the plastic hatch panel.
And now for pictures.
First, this is kind of a rough idea of how I want the sub situated. Since the box will be larger and heavier than the ones I built before I don't want it to hang over the cargo bin, that way if I get a flat I can easily get to the spare.
I've cut the backside away and tried to keep my cuts with the curves of the panel.I've taped it up some and will finish all the prep stuff tomorrow.
Here it is with the MDF sheet behind it. This gives an idea of how much room I'll have around the grill. I'll cut the MDF to size tomorrow and I might see if I can mount it behind the panel. I'll probably surface mount the sub and eventually build a cover to give the appearance of it being flush mounted.
The passengers side has a little less room and looks like it will be more difficult to fit the sub.Worst case scenario I end up running just one sub. As far as my other 4 boxes, once I test them I'll probably put them all on ebay.
