Larz »
https://forums.nicoclub.com/larz-u216291.html
Fri Jul 10, 2015 10:03 am
As for painting over the reverse lamps ..... definitely NOT! You have significantly reduced your visibility behind your car and now you will see only the side view in your mirror (on one side only). You can no longer clearly see the tree stump or anything else that is high enough to damage your car, but too low to see through the rear windscreen. The rear tail lamps can not illuminate well enough for a clear rear-view of your path in situations where there are no street lamps, etc. I don't know laws in all 50 of these states, but it is safe to assume that rear back-up lamps are required by law - else they would not be on every car made.
As for tinting .... I say do the entire lens including the trunk pieces, or nothing. That way it looks uniform and OEM instead of 'tinkered with'. Have a squinz at the pics in my sig. I had an 07 black M and did what I consider to be a brilliant design on my rear lamps. I used VHT to make them a dark cherry red (including the trunk pieces) that still allowed reflection in sunlight). I also did a unique design on the turn indicators giving them strips of amber instead of one large lens. My present M is pearl white so I just did the dark cherry tint with VHT (on the lens, the turn and reverse indicator and the trunk pieces), The slanted strips on the turn indicator would not look good with any color aside from dark grey or black.
