A new beginning
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
little video of the KA-t running...video quality is ok but the screen is angled due to my lack of video usage with this phone. :rotfl
[youtube]http://www.youtube.com/watch?v=A5rC_oK6ASI[/youtube]
240life
It has been a while since I last updated the progress of my car. Things are coming along nicely, but I am taking my time so I dont get the attention of my soon to be ex wife. (she still believes I crushed the 89 and sold everything). I have pulled and sold the KA-T to a friend for $600. I have re-gasketed the SR, removed, cleaned and repainted the block and installed new valve seals in the head. The chassis which is at a different friends house has finally got my Tien's installed at all 4 corners, the complete front end has been swapped for a modified subframe to lower the power steering racks center, modified steering knuckles, re worked power steering rack with power steering cooler, hand made power brace and Wicked tie rods, (this car will be capable of some serious angle). All energy bushings have been installed up front. I have also installed a new braided clutch line and my Stop-tech brake kit (not big brakes, just modified stockers, but this set-up has saved my butt on the track). Now onto the few pics I managed to get on my phone while working :biggrin:
Cleaned engine
Picture of some of the installed parts I have re-furbished.
240life
Just picked and ordered up the last of the pieces to finish up this portion of the project. I purchased a ISIS cold pipe for the ISIS intake manifold, new Autometer water temp gauge, I ordered new OEM flywheel bolts, OEM head to manifold nuts and yokes, OEM rubber transmission boot (no more leaks near the shifter, and some Aki project transmission,starter bolts and washer combo. Should be installing my Sr this weekend along with the transmission and wiring for the transmission. I am heavily considering upgrading to a wiring specialties s13sr wiring harness so I can get a real clean look. :chuckle:
240life
So I open my mail box today and all the way from california in 2 business days is my package from Frsport. This is great Im thinking, the package is totally here quicker then I would have thought. I open it, find everytrhing except my flywheel bolts, called over there and they were very helpful. They are shipping my bolts durring tomorrows business hours, because their last order already went out. They are also paying for the shipping of the accidentally shipped manifold studs back to them. Im really needing these flywheel bolts, it is putting the brakes on my final assembly of the engine and transmission guess i will be installing it into my car next weekend. On the other hand I now have all my parts in the trunk of my Altima so I can bring them to where I keep my car. Hopefully I dont have anymore surprises, its been a year almost since I started this motor, I miss boost horribly.
240life
I have just about replaced all the hardware on the engine for new OEM or equivalent parts. I ordered a new OEM throttle body gasket and OEM clutch pressure plate bolts. I installed my new exhaust manifold hardware, reclocked my turbo, installed new turbo flange bolts and OEM locking tabs. I have to make a new turbo coolant feed line, because when I removed the broken earls fitting the braiding on the line frayed making me cuss multiple times. :tisk:
240life
Finally got around to delivering my engine to where my car was being stored so it could be installed. I cleaned and re gasket-ed the transmission after swapping the bell housing. My friend Ben and I also managed to get the engine sitting in the bay with some of the inter-cooler pipes on. I still need to wire it up, install the drive shaft,and bolt up all the other B.S.
If you have the metal lines on a S13 power steering rack, SELL them to me please. I damaged one during installation of the engine. I also gave away my spare lines last week :frown:
240life
I haven't had much of a chance to update this lately (not that to many people are following anyways), but I have managed to get a little more done. My car is 3hrs south of me so working on it is difficult considering I lost my license due to a good night on Halloween :facepalm: . I have wired up the engine, installed the radiator, secured transmission and motor mounts and drive shaft, installed my FPR and braided fuel lines with inline pressure gauge. My friend Ben fabbed a real clean throttle cable bracket for me and installed it. I still need to wire my lower harness and gauges up, and insatll my oil-cooler. I also need to purchase a high-flow cat, exhaust D/pipe gasket and Rucas to finish this project for the winter. I will try to get down there soon to take pictures and finish 90% of whats left. Stay tuned :biggrin:
240life
NEW VIDEO ADDED
Well since I got some down time I decided to clean up my Photobucket and create a time line of my 240's progression since I got back into them in 2006. There is tons of pictures so enjoy :biggrin:
It started with a 1989 coupe Ka24e rusty as hell underneath, but a $500 price tag was easy to swing.
I went to the Middle East for a bit and ordered this...
It spun a bearing in #2 cylinder shortly after.. so I decided to do a bullet proof bottom end...
86.5mm 8:5.1 pistons
Oem rod shown, but I ended up using eagle H-beam rods (machinist suggested)
87mm Tomei H/G, Oem gasket set, I also used all ARP hardware
Repaired strut towers...
Swapped to silvia front...
re-installed engine....
The silvia converted car was driven for 6 months. Due to rust I purchased anoter 89 coupe. The under carriage of this car was beat, but would pass a visual inspection. The deal was to good to pass up, $1400 for the pair...oh yeah it came with a rust free auto 1993 coupe. The 93 was sold 2 days later, lol.
ugly interior, but it had a authentic Sparco seat and rail plus MOMO wheel
beat sr20de, so I ended up yanking it and intalling all the best components from my two remaining cars :ohno:
fat picture lol.. :rotflmao
cleaned it up a bit
Looking nice and happy....for now :crazy:
interior swapped to black
Drove it around like this for a bit then I picked up a 2871R, DW 740cc's N62 MAF and a Emance tune
did a little of this....I come in @ 4:14 open diff no power steering 1st practice
[youtube]http://www.youtube.com/watch?v=gobRWoGLHzs[/youtube]
All was good...then my wife became a Wh0r3. I knew I was getting divorced so I crushed this shell, sold my motor cycle and hid my parts, I wasn't going out like some punk...Oh yeah I got everything she got nothing by the way :lolling:
OOH new wheels somethings happening in top secret at 2 undisclosed locations at this point :naughty:
Started stripping the Old coupe so it could disappear...dont wory I was going to restore it but there was a TON of hidden rot, it just looked nice on the outside :squint:
All this was done at my buddy Mikes in 1 night. Crap started to hit the fan, so tahts when I decided to crush. It sat for 6 months like this. While the divorce was going on I had liquidated some of my belongings and purchased a 1993 coupe with 120,000 miles. It is rust free with a KA-T that nobody could get running. I ended up keeping this at another friends house. The Ex wife never found out about it, because the only people who knew I had it were the owners of the house :chuckle: During this time I ended up swapping out all the bushings from my 89 with energy components at my apartment, luckily I had kept both complete subframes.
I completed the front subframe and all its components. I then brought all of my parts that I had laying around ( teins, braided clutch line's, stoptech rotors and braided lines, 17 row oil cooler ) to where the 93 was hiding. I swapped out everything I wanted to use from my previous car. This chassis already had a power steering cooler, modified subframe and knuckles, RSR invidia exhaust. on to the pictures again....
Pretty clean KAT..sold after I got it running...needed upgraded fuel pump
Power steering cooler
View of the car with all new suspension and wheels installed
well there you go. It's about 90% done just need time and a little bit more money to complete it..maybe by the end of spring lol :rolleyes:
NEW VIDEO ADDED ABOVE
240life
Current parts list...
95 SR20DET BLACK TOP BORED .20 OVER
ARP MAIN STUDS
CP 8:5-1 86.5MM FORGED PISTONS
ARAIS RINGS
EAGLE H-BEAM RODS W/ ARP ROD BOLTS
OEM TIMING SET
TOMEI 87 MM 1.1 MLG HEAD GASKET
SUPERTECH VALVE SEALS
ARP HEAD STUDS
RE MANUFACTURED CRANK
.20 OVERSIZED KING BEARINGS AND THRUST WASHERS
ATI SUPER DAMPER
OEM OIL PUMP
S14 OIL PICKUP
ARC OIL PAN/ COOLER
OEM NISSAN GASKET SET
WALBRO 255 LPH PUMP
NISMO TYPE B FPR
STEEL BRAIDED FUEL LINES
INLINE FUEL PRESSURE GAUGE (SUMMIT)
DEATSWERKS 740CC INJECTORS
ISIS INTAKE MANIFOLD WITH MATCHING COLD PIPE
ISIS LARGE FMIC (DAMAGED ORIGINAL GREDDY M SPEC)
GREDDY HOT PIPE
TYPE RS BLOW OFF VALVE
MEGAN RACING EXHAUST MANIFOLD (BEING WRAPPED)
OEM MANIFOLD INSTALLED (POSSIBLE EXTRUDE HONING)
OEM EXHAUST MANIFLOD NUTS AND YOKES
MEGAN RACING BMC HEAT SHIELD
GARRETT GT2871R
OEM TURBO LOCK TABS
CIRCUIT SPORTS TURBO LINES
CUSTOM DIVERTED DUMP PIPE
CUSTOM 2.75 INTO 3 INCH DOWN PIPE
3 INCH TEST PIPE
RSR INVIDIA 3 INCH EXHAUST
EMANCE TUNE
CIRCUIT SPORTS COOLANT OVER FLOW TANK
CIRCUIT SPORTS OIL CATCH CAN
CX RACING RADIATOR (HATE IT (KOYO BROKE WANT ANOTHER ONE)
GENERAL MOTORS DUAL ELECTRIC FANS/ AFTERMARKET CONTROLLER
CUSTOM SUCTION KIT
REUSABLE AIR FILTER (NON OILED)
ACT PRESSURE PLATE/ STAGE 3 CLUTCH 6 PUCK SPRUNG
SPEC BILLET FLYWHEEL
ISIS BRAIDED CLUTCH LINES
NISMO PIVOT BALL
DRIVE SHAFT SHOP ALUMINUM 1 PIECE
WELDED DIFF (CURRENTLY OFF)
UNKNOWN LSD (CURRENTLY INSTALLED)
ENERGY SUSPENSION MASTER SET
NEW BALL JOINTS (MOOG)
NEW SWAY BAR END LINKS (FRONT (MOOG)
POWER BRACE
CUSCO PILLOW BALL MOUNTS
TEIN BASIC COIL OVERS
TEIN INNER AND OUTTERS WITH SPACERS (SPARES)
WICKED RACING INNER AND OUTTERS WITH SPACERS (CURRENTLY ON MIGHT CHANGE)
CUSTOM MODDED FRONT KNUCKLES (DANG DRIFTERS)
SOLID STEERING BUSHING
CUSTOM MODDED SUBFRAME (REDUCES BINDING AND POPPING WHEN YOUR LOW) DANGDRIFTERS)
REMANUFACTURED STEERING RACK
LIGHT WEIGHT ALUMINUM P/S PULLEY
STOP TECH SLOTTED ROTORS
HAWK PADS FRONT AND REAR (REAR SOON TO BE D1 SPEC PADS FOR MORE GRIP)
STOPTECH BRAIDED BRAKE LINES
REBUILT CALIPERS ALL 4 CORNERS
XXR 522 16 +0 OFFSET WHEELS
HANKOOK HRII 215/40H16 TIRES
OLD SKOOL WINGS WEST SIDE SKIRTS AND REAR MUD FLAPS
MOMO JET STEERING WHEEL (HORN WORKS PROPERLY)
BOSS HUB ADAPTER
SPARCO RACING SEAT
SPARCO RAIL
CUSCO DRIFT BUTTON
AEM WIDE BAND
AUTOMETER EGT GAUGE
AUTOMETER WATER TEMP
AUTOMETER VOLTAGE
AUTOMETER BOOST/ VACUM GAUGE
HDI ELECTRONIC BOOST CONTROLLER UP TO 36PSI
PIONEER HEAD UNIT
JL AUDIO TWEETERS
ROCKFORD FOSGATE MIDRANGE
BATTERY RELOCATED TO TRUNK USING HIGH QUALITY WIRE AND GOLD PLATED BATTERY TERMINALS
OPTIMA RED TOP BATTERY
POWER STEERING COOLER
CUSTOM 12 ROW OIL COOLER SOON TO BE INSTALLED
240life
Well since the nice weather is now hitting Maine I decided to go to where I store my 240 and do a little more work.
First I installed my new Autometer water temp gauge, S14 drivers seat, and relocated my wide band to the center vent.
Then we decided to remove the Burgandy front end so I could tuck the drivers side wiring and spray the front in a gloss white.
Some of the pieces painted.
My friend Ben stripping the nose.
Running the wiring through the frame
We then proceeded to wet sand the remaining paint with 2000 grit wet sand to remove staining of the paint and peeling clear. It's not finished, but is looking 100% better.
Started mounting the front end.
Image.
Durring the remainder of the time I started getting the SR ready for fluids. I drained the old oil, filled with cheapo oil from walmart to do a flush, then turned it over several times to loosen any shavings that were in there from the head repair. I had found a stripped cam journal bolt after assembly that needed to be tapped and drilled larger. After the engine had been turned over for a bit I drainde the cruddy oil and replaced it with Rotella_T 1540 and a new NAPA oil filter from a 92 sentra se-r.
After the oil change I mounted my power steering cooler, changed the pump and added fluid. I then added valvoline synthetic to my Transmission, which started leaking from the front cover. We dropped the subframe so the transmission would clear the tunnel and repaired that leak. We proceeded to start the SR...but the CAS timing was off causing weak or no spark to some cylinders. After fixing that we let the engine sit over night to clear any gas wash. The next morning she fired up, but injector 2 was stuck, so I removed it and replaced the issue, It now runs pretty good.
After all the mayhem I decided to in stall my oil cooler set up. I made an Aluminum bracket to hold it to the radiator, cut and ran my braided lines. The cooler is mounted where it is because my hood is creased due to being outside under snow all winter, so we are just going to add either a WRX vent or something else in to allow good flow, plus it keeps it from getting damaged easily.
it looks crooked, but its the camera, im using my old cell phone. The cooler sits pretty nice right now.
Random pic of how it sits as of easter sunday 2011
mindovaanything
Car: S13 Hatch
I like the oil cooler, and the cluster of all aftermarket gauges, good stuff
240life
Thanks. The intercooler set up is going to change, but I need to modify a few things first. I still need a vent in the hood to even get air flow if it stays in that location, or I could modify my intercooler piping (which I dont want to do) and locate the the cooler in front of the drivers front tire.
240life
Added a S14 rear and front seats this last week...now onto the pics :chuckle:
rear seat installed
pic from the front
gauges and steering wheel
rest of the interior
the rear seat was pretty straight forward, just remove the old seat, install the s14 lower first using washers and self tappers to secure it to the chassis. The upper requires you to remove the latches from the back of the car and move them to where they are usable (you need to grind down the tabs first then drill new holes and secure with bolts, nuts and washers)...eventually I need to make the lower brackets so it can be flip down like stock.
