A multitude of problems.
MR2NER
Car: 1991 240SX
Well as usual I searched but found that no one else has had this problem. When my hedlights are extended, the driver's side headlight housing shakes, thus causing an annoying pattern of light. How do I tighten or fix this problem?
trpower7
Tighten the Mounting bolts. raise your headlight, walk out to hte light, put your hand on it and try to move it. Find where it flexes, tighten the bolts. There are six or so mounting bolts that hold the housing to the core support, you can get to them by taking the headlamp out. This one is kind of a no-brainer though.........
MR2NER
Car: 1991 240SX
sorry for the stupid question. Thanks for the help though.
