A more accurate Power Balance test
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Can anyone who know how to write code write a little program that compares engine RPM during each pistons compression stroke?
If the cylinder is low on compression the piston will move faster than the rest.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Wouldn't it be easier to just measure the compression with a compression tester?
Infinitiguy19
I know I keep coming up with the idea's to make things easier (To find out engine health), Just beating around the bush if you will. But yeah you are right measuring compression with a gauge is the best way. But the above method could be done in five minutes with a computer VS a few hours with tools.
