Exactly why I no longer go to a shop for a machine fluid exchange..... I will settle for 85-90% fluid exchange by doing multiple drain/fills {6} myself at home and avoid the pitfalls of allowing a possible untrained person touch the transmission, or worse yet, using an unclean machine to get an additional 5% of the fluid changed out as compared to doing it yourself, to your standards and satisfaction. The $100-150 you save by doing it yourself can be better spent on top quality full synthetic ATF or performing the drain/fills more frequently.jimbyjimb wrote:Absolutely right! If the machine does not use shop air, you have no worries. You are also completely right about insructions and so forth. It was the shop's responsibilty to properly educate a 19 year-old entry level technician on how to properly run that machine and furnish him with paperwork to study it's proper operation. Proper training was not facilitated and niether was proper paperwork. I could have gone out on my own and searched for knowledge but at the point they got the machine I was on my way out the door from extremely low pay and no appreciation for a year's hard work. I should have worked at an independant shop, and if I had I would likely still be a tech.
I agree here. That's why you shop around and get a feel for who you're dealing with. I went looking for a GOOD shop with a BG or Sun machine about two months ago. I went into a lot of shops, with and without BG banners. Most of them scared me away. I was tempted to actually tell a couple of them that that simple question/answer session scared me so bad I'd never let them near my car.qship96 wrote:I wouldnt trust 98% of the places that hang the BG banner flag on their shop wall- most are run down looking gas stations with young {unskilled?} looking neighborhood flunkies working there- wouldnt even trust em to change my oil correctly.
THAT's what I was trying to say. As usual Jesda reads my mind and transcribes it more clearly and succinctly.Jesda wrote:I'd worry about doing any work at a shop that you can't fully trust, even for oil changes.
I had mine flushed after specifically hunting down a BG shop. I had visited an independent shop before that claimed they did transmissions, but once the guy heard the age of my car, he declined to do it. Must have been used to less hardy vehicles of the same age or younger crapping out.Q45tech wrote:Don't confuse the shop air powered transmission machines with the BG Machine which adds no pressure but relies on the transmission internal pump to just pump out old and pump in new.
It's the added pressure from the old style machine that does them in.
A replacement bladder in a BG machine cost $1,000 so cheaper machine use an air pump with the attended RISK of the operator not knowing that 30 psi is max for a JATCO where shop air may be 100 psi..........bam a destroyed transmission.
Male techs just like males in general may not read the instructions carefully and do required research!
Now circulating the {PRIMARY STEP} BG Quick Clean SOLVENT thru the transmission for 15 minutes does loosen the clutch wear material and varnish is often hurried or not understood!
The PROPER exhange process and analysis requires a technican familar with JATCO units to achieve best results.
Look of ATF before contemplating the process, timing the exchange with a stop watch and analysis of pressures created by internal pump.
Most importantly is deciding whether to do the entire process again immediately based on color, smell, and taste [if you have the tongue for the job]. Like a coffee or wine taster.
I see many where once is not enough to restore the circulating ATF to perfection.
If you think about it working an oil well or refinery or eating fast food is much worse than tasting/smelling a drop of petrochemical.
However 60ml [4 tablespoons] of 50/50 antifreeze might be lethal [LD25]{LD100 is 1.4ml/Kg of pure ethylene glycol}
Wife poisons 2 with AF:http://www.courttv.com/trials/....html
The solution that Q45tech is correctly advocating is the best, keep exchanging and chemically flushing until it is clean as new. Leaving varnish and crud in is no gurantee it won't break loose at a later date!subtle_driver wrote:I'm a mechanic at a shop in RB, we use a BG machine and I was trained on how to use it properly from both the older experianced techs and the owner and the BG rep. himself. We usually don't use chemicals for the flush process as it can free up some sludge that can get clogged in the solenoids or passages. we generally just use the reccomended fluid from the factory service manuals and let it go through the process.
I drop the pan on my q45 and change the screen. but next time i will just do a flush with the bg machine or take off the pan and weld on a drain plug.
I agree with this, unless it is super old, ie. a toyota corrolla with 200k miles. but it just depends on the car; case to case basis.maxnix wrote:The solution that Q45tech is correctly advocating is the best, keep exchanging and chemically flushing until it is clean as new. Leaving varnish and drud in is no gurantee it won't break loose at a later date!
what update are you talking about?i read all the tsb's on my car and saw nothing about a transmission pan update.do you have more info or a link? is it a warranty repair? that would be cool! please give me more info on this! thanks man!maxnix wrote:If your car has the none drain hole pan, your car must have never been updated if I understand the early RE04 updates.
hmmm...all i know is my transmission is the origonal unit that came with the car from the factory in 1990. and i have been drag racing and autocrossing and driving it everywhere with no problems. its got a 94 tcu and i reprogrammed the ecu for a higher rev limit and adjusted the vvt and ignition timing and fuel mixture to handle e85. so, i basicly just have a pan that has no drain plug. i guess i'm still gonna take it off and weld on a bung for draining the fluid.thanks for the info on the updates tho! appriciate it! if i see an updated pan at the boneyard, maybe i'll pull it for myself.Q45tech wrote:Kind of complex inthat some of the EARLY replacement Nissan rebuilds came back with old pans without drain plugs.Some of the brand new transmission held in spare parts inventory had no drain plugs.
By 1994 all the replacement tranmissions had drain plugs.
Non Nissan remans [independent rebuilder] didn't change drain pains. Junk yard trannies may not have drain pans.
Must research dealer documents to see what happened [but they won't differentiate pans].
Updates are just that rolling changes in manufacture without recourse.
Care to elaborate? What can happen with a mechanical ATF exchange that couldn't happen with normal operation?Q45tech wrote:
I agree that no 19 year old transmission should be flushed even with BG system.
